Dany not sure where to get wrap from Islamabad :s.
Xulfiqar bhai today I took the wiring out from inside the car and checked NE G Signals all 6 are properly connected. Than my mechanic thinks Map Sensor wiring is not proper so checked that it was also fine. So i was wondering why its giving code 12.
Finally I checked STA as the ecu was giving sta missing. The STA signal some how is missing from the wiring even though I opened the wiring loom and took out wires they all seem to be properly connected.
Anyways for testing i connected STA and Bingo car started engine was smooth no more black smoke did a test run and in runs like a beast keep spinning wheels even in 2nd gear..
Checked codes again this time no codes. Test run again this time Rev LImiter also kicked in (It was not working before) than check engine light (I connected small bulb to holder for check engine light as meter got no light) turned on.
Checked codes and it 52. 52 is Knock Sensor so i will install that too its missing from engine block though wire is there for it.
Now engine is running very smooth
