Ok A/C is tested we were looking for the 5 Piston Denso Compressor and installed Doowan Reciprocating (Piston) Compressor i guess the same on that comes in the Spectra and also called the 15 Number in Denso even it says 15 Number. I have seen this compressor comes stock in the Corolla X engines (1.5 VVTI).
I told my a/c wala that this time I need a a/c that works better than my previous car especially on low RPM so this was his suggestion.
To install it we had to buy a new bracket (Some say this also comes stock in 7A but pathans remove it as it sells at 4500 Rs for compressor and 2000 for bracket and normal denso unit is for 1500Rs)
Results:. Yesterday's test with my previous denso compressor the rotary ones the low side i have never seen them go below 35 or stays at 40 at idle but with this (Remember we are not using multi aisle condensor for now) the low side right away showed as low as 20 and even touched 15 hmm and cooling is very nice and load that is similar or even less than the rotary one...
So Far soo good
