As per my sources, the Chinese radiators (A grade) are pretty good. Old radiator is like old brake pads, battery or tires.... it has a certain life and then moves on
Honestly speaking, when I had to change mine (for 1kz engine), I went for NEW aluminum radiator (make: ThaiCool Radiators). It is working fine to-date... no issues.
If original OEM is copper and you find a kabli in copper (which upon examination, is never opened / repaired), then surely that would be the best case. "BUT" if you find unopened / non-repaired one!!!
badami bagh se mil jaeyga easily. they have 2 models, 1 for manual gear vehicles, other 1 for auto (like one in above pic). Auto is a bit expensive than manual type.
Salam Bhai nose cut ka rate hai 80 series ka 28k and he said 25 Tak mil jayee ga saf suthra hai
Another one with sheild 26k without shield 22k
Question: These hoses are to cool the gear oil or to heat the gear oil for cold areas??
No. Do not take this chance at all...
It would be a big risk and believe me once it starts leaking u cannot move
Purana radiator utaar k pindi saath le jao doosri gaari may. Check and select a good kabli... and so on.
Aur gear oil wala radiator ka chamber achiiiiiiiiiiiiiii tarah khaali kerna nai tau jahan rakho gay wahan aik nishaani chhoray ga radiator. Aur khud lift kertay huay aap k kapray bhi uski nazar ho jaeyngay
avoid taking it with a risky radiatorare the available Kabli ones with warranty and in mint condition?
Was this message addressed to me
