COMPANY DETAILS
‘Made in the U.S.A.’, Boss Hoss Cycles, Inc. is located in Northwest Tennessee. Our manufacturing plant, office and warehouse facilities encompass 22,000 square feet on seven acres at 790 South Main Street in Dyersburg, TN. If you’re ever in the area stop in and check us out, whether it is just a quick stop by the showroom featuring cycles and apparel, or a pre-scheduled tour encompassing our entire manufacturing facility. From the size of our facility to the number of dedicated employees on staff, you can see first hand that the Boss Hoss is manufactured in a clean, streamlined facility where its crafters take great pride in the products they produce.
DEATILS
Engine
TypeLiquid Cooled V-8
Horsepower502 @ 5200 rpm
Torque567 Ft.Lbs @ 4200 rpm
BlockCast Iron - 4 bolt main
CylindersAluminum (110cc)
Valvetrain2.25"Int. / 1.88"Exh
Size502 c.i. (8200cc)
Compression9.6:1
CarburetorHolly 850 cfm
Exhaust2.5" with dual mufflers
Transmission2-speed semi-auto w/rev.
Final DriveBelt, Gates- Polychain
Dimensions
Overall Length108"
Wheel Base82.0"
Seat Height28.5"
Rake33.0 degrees
Grd. Dlearance4.5"
Frame Width31.0"
GVWR1827 lbs.
Dry Weight1300 lbs.
Tires/Wheels
Front130/90-16, 3.50"x16.0"
Rear230/60, 7.0"x15.0"
Suspension (Adj. Preload)
Front63mm inverted forks, 3.5" travel
RearDual 13.5" coilover shocks
Brakes
FrontDual four-piston calipers, 12.6" floating disc
RearSingle four-piston caliper
FuelTank8.5 gal.
Reserven/a
High/Low MPG18/13
