Rpm going up and down after throttle body cleaning..what can ne the issue?
Did you get the calibration done after cleaning?
Nop..what does that take???can it be done apart from honda?
Yes, you can get it done from other workshops if they have Honda Diagnostics System..They just connect it to the car using OBD and then calibrate the values to stabilize RPM's. I had to get it done after getting throttle body cleaned because RPMs were fluctuating.
What makes this happen?it was just a regular cleaning what makes this happen?
Idle and TPS Sensor usually end up getting screwed during cleaning so they need to be re calibrated.
From where did you get it done from?
Honda Point
Charges?
I can't recall the exact amount..I think total charges were something like 8000 rs but that also included other things like Tuning, Alignment, Brake Service etc.
W.salam,
Go for them - They are extremely good. I switched from Michelin Energy Savers to Advan DB and they are very very good.
Does Tracking World offer Android Based Multimedia unit for 8th gen?The original (oem) navigation is soo outdated, dull, and slow now...
Charges would be 500-1000, every place is different.
Basically you have to do an idle relearn procedure. There are videos on idle relearn procedure for civics, search for them. I tried this on a city, it worked.
Got it done for free lolTook the computer from an electrician hooked it up selected honda civic went to engine portion and there was tps calobraion option which i selected and pressed ok and it was doneBut the issue is there due to which i had to get it serviced...the cars rpm drops down alot like it even goes below 500 when i release race and press the clutch and then comes back to700 where it settles...but it used to idle on arnd 900 rpm from the beginning but now it settles on 700 and i face vibration etc
Generally I think 8th Civic idles at 700 or 750. Mine's idle RPM is 750 since day one and no vibration or any other issues.
Minw is even idiling below that to be exact at arnd 600
Fellow members,
I need to ask the price of 2008 Civic VTI ORIEL in white Lahore reg...Which is in its brand new state since driven only 24,000km's
hello guys......i have bought 2011 civic reborn vti oriel manual 84k done on meter throughout petrol driven.
Please advise if it has a timing belt or chain? and should i need to get it replaced or not?Plust what else should i change/ replace as i have bought a used car? Please advise.
It has timing chain.Check engine mount, check catalytic converter too to see if it is clear or requires cleaning. Not sure abt fuel filter however i got it changed on 90k as per manual.
thanks for your response. should i change its timing chain? i just got engine oil, oil filter and air filter changed till now.
mounts are ok. will check catalytic converter and fuel filter.
