Thank for Share the nice Information....................
He never tried.....neither did I
i have replaced new battery after adding acid only charge 45 min and mount in car and apply grease on terminals is it ok or any specialy instructions to maintain battery life
@xulfiqar i bought used throttle body its throttle stop screw is at original setting but i noticed that even on closed throttle there is very veryyy minor opening in plate... (i saw it by keeoing the throttle body in front of sun then i can see the other side across the throttle however very little opening it may be due to wear n tear of plate or wall of throttle body.....
shoukd i adjust the throttke stop screw to close it
petroleum jelly melts at low temperature, - its also not tenacious meaning it can be easily wiped away with even a tissue paper.
You yourself can make it, pinch per teaspoon (that ratio good enough for you?)
