Clean black tyres add to the beauty of car. Keeping tyres clean all time is a challenge especially in muddy areas and streets with water flowing from houses all time resulting in a mess. Normally we use a pipe simply connected to tap or a bucket and a mug. Here is a simple device which we can use for cleaning tyres, engine bay and other areas which are hard to reach. 2 big advantages of this simple device are
1) We can control the flow of water any time which means no wastage of water while busy with cleaning.
2) Pressurized and concentrated flow easily removes dirt + easy access to any area due to compact size.
Things we need are 3/4 inch diameter soft rubber pipe ( i used 24 feet length ), shower known as muslim shower in sanitary shops, 1 inch diameter steel wired pipe 12 inch piece, 3/4 and 1 inch nozzles with connecting socket, clamps and taflon tape.
Note: 12 inch steel wired pipe piece and nozzles with socket are optional. If soft rubber pipe can directly fit on tap then you don't need them. In my case I am using wash basin tap therefore I made the converter. Total cost is 850rs.
