Hi every one I'm from Jordan & this is the first post for me,
I'm bought a 2006 civic 1.8 R18 with automatic transmission
Some times (once every week) when put the gear on R it take a while then hard engaged, also when but into D hard engaged & the car start from the 2nd gear then 3rd but not in 4th or even 5th gear.
Just When I turned off the engine then on everything is okay!
No check engine or D blinking , but when the problem is appeared I check the DTC :
A/T Clutch Pressure Control Solenoid Valve A performance Stuck OFF
Screen shot attached
https://drive.google.com/file/d/1GAhFOnzIy3690gVHSFq5hnVAYkcT8UN6/view?usp=drivesdk
A/T Clutch Pressure Control Solenoid Valve A cleaned, 5.9 ohms & nice clicks sound then replaced.
Every gear is shifting smoothly and on time
*Replaced the in line filter with Transmission fluid drain & refill for one time
Car done 237K Km
Sorry for my language & please help me
With all regards
