Asalam o Alaikum.
This is Dr. Adnan. (MBBS). 03470310109
My friend-cum-brother and electronics guy ABID (03034485038) Available only in LAHORE
I wanted to do this a long time ago but time shortage.
Now that I have time, I hope it helps not only Abid but you guys.
(Advertisement)
UPS
- Abid makes upses of different capacity.
- Starting from ranges between as low as 600 watts to 1200 watts to 1600 watts to 2200 watts or 3000 watts or as required by the buyer.
STABILIZERS
- As low as 300 watts to 2000 watts to 5000 watts to 10,000 watts and as requested by the buyer.
SOLAR
⁃ Abid says he makes real automatic day and night solar UPS/inverters. (Info updated as received)
And if you are in contact with him, you can ask what else he can help you regarding electronics that sometimes even engineers can't do.
Since cheap desi ups makers have made you look for chinese inverters.
I tell you why is he different than the local ups makers or inverter companies or even international branded UPSes.
He is experienced with more than 15+ years. Honest. Not really honest. Who doesn't lie. What I mean to say is that, He enjoys seeing his products having the utmost quality and safety as one can give in practical amount of money and time. In other words, he hates to make cheap product. Thats against his existence in this regard.
For example, he will tell you he makes 1000 watts Ups in certain amount of money. But actually he will make it 1200 watts. And tell the customer that it is 1000 watts. ( instead of others who say they make 1000 but use either cheap parts or less time or make 400-600 watts and tell u otherwise).
Why does he do that, because he does want his product to have longevity, as well as taking all the load of 1000 watts of a house or place and still remain cool. Because we pakistanis try to take or test things or relationships to their limits sometimes.
⁃ And to top that, he uses the best quality there is in market to make his products. E.g; Using the best solder there is to have not only longevity but take the burden of the load easily and does not want the UPS to fail.
⁃ He would use the right width or size of wires inside to take the load or beating.
⁃ He would use pure copper wired transformer. Neither silver winding nor china copper. (U can get it checked by others)
⁃ He would recommend using his UPS with the top of the list practical battery company or if customer is financially hesitant, he'd recommend cheaper but better quality compared to others. But when you can go for quality, he will recommend you the BEST one.
The moment you realize this guy won't cheat you or cannot possibly make his product cheap. You will see all things clearly why and how you are being cheated by others.
As we all know markets use monopoly to either set the price range or quality standards in those price ranges. ( I condemn bad quality or wrong advertisement but corruption or rents are forcing people to survive by any means possible and build something for themself in this money inflation causing society)
But this guy wouldn't bother. He just cannot imagine himself making a cheap product. As far as what I have seen so far after knowing him for 2-3 years.
Customisation:
This is one of many things what sets him apart from competition.
Many may be able to do little to many customisations.
But when it comes to ABID,
⁃ As he uses good quality products, either they won't break and if so by any factor or human error, they are highly repairable. And can be repaired again n again if someone given the probability reaches that many repairs.
⁃ Even though he updates his UPS functions as he imagines the newer ideas. He puts as many functions in his ups to be able to take all kinds of beatings or load bearing.
⁃ But still can fine tune according to each customer's particular need or when customer is not able to decide. He will decide the best for you and his ups.
⁃ Such as having too much load shedding and less time for charging, his ups can not only charge quickly as much as battery can take neither higher than battery can take nor slower. Leading to good, healthy battery life, capacity and backup and happy customer. But giving backup for rest of the day unless load is too much and battery is getting drained much quicker than its capacity to charge as fast as possible. This is your battery's capacity limit not UPS problem.
You will get not only good battery backup but also your batteries won't fail. And give their best possible life. Minimum 2 years to maximum 3 year life and some exceptions take it to 4 years.
You will not have to worry about battery being damaged or water being refilled too early or each week. This happens when the battery is dying. Which is after at least 1-2 years. Not after 3-4 months or 6-8 months. Thats a sign of bad ups or inverter.
There is much more I will update later in this thread.
Positive and negative or (sceptics) comments are welcomed.
I will post pictures of his UPSes later. And comparison with inverters generally upon request. Thanks.
To each his own.
Allah hafiz.
Fe Aman Allah
