File #4: Image Uploaded
copying file File #5:
Ghani Motorcycle Self Start with Remote Control.
Gi 70 Milage is the only thing u get with Gi 70 that is also 96 Km Per Litre i owned a 2006 Gi 70 9 months old
The Suspension is Very Nice. If u drive for longer period of time with 2 person sitting behind...
Good things about 70 RESALE is good...
Suspension is better tires are 6 ply wide tires compare to 70cc 4 ply tires...
And it has a good gear box not like 70s which is very jerky type of gear box.. (All bikes above 70cc have better gear box)
1 Litre meh 84 Km Guaranteed.
Self Start & with Remote Control.
Alloy Rim
Heavy Duty Front Shock Absorber
Adjustable Rear Shock
RPM & Speedo Meter with Gear Indications
Technical Specifications
Engine Type: 4-Stroke Air Cooled OHC
Displacement: 72 CM
Bore & Stroke: 47.0 X 41.4 mm
Compression Ratio: 9.1 : 1
Max Horse Power: 7.0 PS/8500 RPM
Max Torque: 0.55 Kg-m/6500 RPM
Overall Length: 1905 mm
Overall Width: 760 mm
Overall Height: 1041.5 mm
Wheel Base: 1219.2 mm
Ground Clearance: 150 mm
Dry Weight: 88 Kg
Starter System: Self
Transmission: 4-Speed Constant Mesh
Clutch: Wet-Multiple Plates
Rim Type: Alloy Rim
Front Tyre Size: 2.50-17- 6 PR
Rear Tyre Size: 2.75-17- 6 PR
Frame Type: Backbone
Fuel Tank Capacity: 9.0 Litre
Ignition Type: Electronic Ignition CDI
Engine Oil: 0.7 Litre
Ghani is giving 12 Months or 12000 KM warranty on there bikes..
Honda is giving 6 months or 6000 KM warranty..
Now choice is urs
Jini Toadi Oni Sadi.
Malik Asad
0300-8477409
