Yesterday i swapped right side axle both inner outer with kabli one, also replaced front wheel bearing of left side along with new shock, after that all went smooth, later while driving ABS light came on, i checked the fluid, bleed the brake in cross pattern, rest ecu, took all abs sensor off cleaned them but still no luck. What could be issue? Also my electrician checked all fuses aswell but no luck.
CIVIC ES prosmatic.
Sent from my HTC One X using Tapatalk 2
