I am local auto electrician, not professional. Please help,
Problem is my friend bought prius 2007 with alot fault code.
But still abs vsc light and fault c1345 linear valve offset not learning.
I try it many method. First aux battery voltage 10 volts change battery non prius may be that the problem?
Or may be these vehicle have issue like this.
And some time accumulator pressure low fault come.
I check brake oil is ok, i calibrate many time,
1 erase code, but remain c1345
2 reset memory
3 calibrate zero point
4 and the linear valve learn
During this the abs and vsc light flash quick for 80 second (calibratoin time is 120 second in techstream)
And brake warning flash slowly according scanner.
But when its done i check the code its there.
Note,
(I could not erase c1345)
Further more i want to check skid ECU power +B and ground source,
check leak in brake oil,
I want to change battery to genien prius (something 3.1 amp 12v)
Pleaze help me.
Any one
Ask xulfiqar
