AoA guys
I have a suzuki swift 2011, recently I encountered a problem :
I often goto my village which is 4 hours drive , i noticed that my ac compressor starts rattling noise on low rpm and cooling also shutsdown but when i speed up the sound is gone and cooling is fine.
I also noticed on just two separate occasions that i was going on low rpm(low speed) ac rattling was occurring i didnt turn off ac and after sometime the car started heating up so i turned off ac and gauge slowly came back to normal position and didn’t heat up rest of the journey ( almost 3 hours). This thing happened just two times.
Now my question are :
1) what is the solution of rattling compressor ?
2) the heating up of the car is just due to bad compressor ? Or i should check anything else because car doesn’t heat up even in hilly areas. Heating up just happened two times with AC on
Thanks in advance
