Ask him to check the pressure head of the compressor , if its fine then ur compressor is fine
The next thing to check is the condenser , if its NOT allowing gas to flow through, u'll observe the compressor bearing load , either clean it aur replace it
P.S the bottle aswell
Experienced the same problem few days back
Anyways if it still doesn't work the way it should , then its TURBO LAG
