Did You Check The Climate Control Thingy???
The Thermostat Is Responsible For Tripping The System As Per Temp.......! Any Betterment In Night???
You Can Also Check Your Cabin Filter 1st and Clean It Up Also....Clean You Condensor With Mild Pressure Air And Then Spray Water And See If It Gets Any Better
