correctly restoring such a car in Pakistan requires that you carefully remove every part and label it, then put everything back together with every little clip, screw etc. It will cost you dearly, bear that in mind. e.g. the engine parts are cheap but I doubt the engine will be needing any attention, the A16 is TOUGH. The expensive items are its plastic body work parts, grille, bumpers corner lights, back lights etc. other parts that are expensive are, radiator and condenser, the A/C compressor and sorting out the dashboard vent selector buttons which are vacuum operated, replacing the vacuum pods is expensive business and you cannot find them used. Getting the seats re-upholstered in original fabric is expensive too.
The suspension bushes will be needing attention now, they are a little less in number than a civic but are expensive.
A proper restoration with mechanical work can cost you about Rs 120,000 to 200,000/- or even more on this car depending on the quality of work you want.
