Adjustable Over-Voltage and Under-Voltage Protector Relay - with Lcd Display
Save your Electronics Appliances from Electric Fluctuations and prevent from Burning.
Protect all your Electronics Items from Over-Voltage and Under-Voltage with this Automatic Adjustable Protector Relay.
In case of Over-Voltage or Under-Voltage or Over-Current fault in Wapda Line, this Relay will automatically Turn OFF Power instantly and will save your Electronics Appliances from burning..
When Voltage will became Normal, this Relay will Turn ON Power itself...
Useful for Homes, Offices, Shops, etc
- You can easily set the Over-Voltage and Under-Voltage Value yourself by simply pressing the Button.
- You can also set Current Value for Over Current Protection.
Easy to install, shows accurate Voltage and Current on LCD.
Rated voltage: 220V
Rated current: 1A-63A (adjustable)
Under-voltage action Switch-Off value: 210V-145V (adjustable)
Over-voltage action Switch-Off value: 230V-300V (adjustable)
Price Rs 3000
Cash on Delivery to all Cities..
Contact: 03215260420
Call, sms, whatsapp, inbox for info and order..
