Wa alaikum as Salam
In your budget you may try to find:
Toyota Prado 96-97 models with 1KZ-TE
Pros. High resale value, proper 7 seater
Cons. Old shape seems outdated
Toyota Surf 96-99 models with 1KZ-TE
Pros. Shape is more aerodynamic as compared to Prado
Cons. Comparatively lower resale value and it is a 5 seater
My suggestion would be to try finding anyone of the above but it should be maintained properly.
But keep it in mind that you need to replace its timing belt, bearing, all of its oils i.e. gear oil, tranfer box oil, differential oils, air, fuel filters, worn out suspension bushes etc. to name a few, so keep atleast 1-2 lacs for this work.
