Hello All
well as per CNG Crisis.......i am shifting my ae101 4afe (IMC) model to OEM specs after converting it on M/T....Its A/T From factory...!
i got it with CNG and didn't check into it much........!
what i notice Now is this model came with no 02 sensor but with thing called resistor variable...!
its a thing located very next to passenger side shocker wall inside hood.....i havn't seen its purpose actually but as i check...it shows 4.9kOHm's resistance b/w top 2 terminals ....!! so i want to know does this thing need to be adjustaed or its just something constant..???? there is a round knob thing inside which looks fix to me..
pics might help
89661-12800 is my ECU code....which doesn't have o2 sensor from factory....!!
i will check TPS ISCV and injectors and adjust timing...but since it have no 02......seems like this ecu works either in open loop all time which is not good for F.C
Kindly advice and comment.....specially @xulfiqar
Best Regards
F.K
