After 100000KM, on Corolla 2015, what needs to be checked and replaced
Please check owners manual. It has the checklist you require.
Just the normal maintenance if you aren’t facing any issues.
Coolant needs to be replaced too at 100k.
If auto then do check fhe gear oil on immediate basis if havent done already....apart from that nothing specific needed...check plugs coolant etc thats abt ii
For Corolla it really depends upon what cc engine is there .but common things to check and replace are
Thanks All
I have manual GLI 2014 odo is 55,000 I checked with Toyota for gear oil, they said it should be changed at 80,000 km
Perhaps you mean 20,000 km
Front control arm bush, get them checked. Replace coolant, brake oil and gear oil if not replaced previously.Replace fuel filterClean catalytic convetorClean throttle bodyCheck spark plugsChange brake rotors if you’re facing serious vibrations from brakes.Check brake pads if they need to be changed or not.
