[quote="omer91, post:62, topic:104288, full:true"]
Changed pcv bt the problem still persists !
When removed the intake manifold... Noticed that the intake valves were fully black n sticky... Carbon + oil !
Any chance of valve seals being the culprit ??
[/quote]
please confirm it that ur car is not giving blue smoke at cold start up..
excessively wornout valve seals can also cause oil in intake. plz do the wet compression test .. it will confirm that it is not the wornout rings that is causing excessive blow by leading to oily intake.
