yes for zr series pcv valve is located behind the intake manifold
please look carefully at the picture ! with attention !
yes the pcv is located on the block. and to remove the pcv you have to remove the inake manifold first.
the steel PCV valve under the manifold is in PKDM then am sure it is not an item to fail before 500,000 engine life.
1 spare wheel for honda car is purchased ~!~
Recently i overhaul the diesel engine from mechanic In morning engine can start in half selfWhen the engine can heat if turn off they can not start After 2 after engine can cool down he started quickly I run 300 km but the starting problem can still Any suggestions about this
Yes... u should wait......I no the reasons very well....
