MF I35.
<TABLE class=tdData3 cellSpacing=0 width="100%"><TBODY><TR><TD class=tfld>Production years;
</TD><TD class=tdat>1964 - 1975
</TD></TR></TBODY></TABLE>
<TABLE class=tdData3 cellSpacing=0 width="100%"><TBODY><TR><TD class=tfld>Tractor type:</TD><TD class=tdat>Farm/Agricultural tractor
<TABLE class=tdData3 cellSpacing=0><TBODY><TR><TD class=thdr colSpan=2>Production:
</TD></TR><TR><TD class=tfld>Manufacturer:
</TD><TD class=tdat>Massey Ferguson
</TD></TR><TR><TD class=tfld>Factory:
</TD><TD class=tdat>-unknown-</TD></TR><TR><TD class=tfld>Total built:</TD><TD class=tdat>-unknown-</TD></TR><TR><TD class=tfld>Original price (USD):
</TD><TD class=tdat>$4385 (1975)
<TABLE class=tdData3 cellSpacing=0><TBODY><TR><TD class=thdr colSpan=2>Variants:
</TD></TR><TR><TD class=tfld>2135:</TD><TD class=tdat>industrial tractor</TD></TR></TBODY></TABLE>
ENGINE:
Perkins 3-cyl diesel
<TABLE class=tdData3 cellSpacing=0><TBODY><TR><TD class=tfld>Manufacturer:</TD><TD class=tdat>Perkins
</TD></TR><TR><TD class=tfld>Model:</TD><TD class=tdat>AD3.152
</TD></TR><TR><TD class=tfld>Fuel:</TD><TD class=tdat>diesel
</TD></TR><TR><TD class=tfld>Aspiration:</TD><TD class=tdat>natural
</TD></TR><TR><TD class=tfld>Cylinders:</TD><TD class=tdat>3
</TD></TR><TR><TD class=tfld>Valves:</TD><TD class=tdat>6</TD></TR><TR><TD class=tfld>Bore/Stroke:
</TD><TD class=tdat>3.60x5.00 inches [91 x 127 mm]
</TD></TR><TR><TD class=tfld>Displacement:
</TD><TD class=tdat>152.7 ci [2.5 L]
</TD></TR><TR><TD class=tfld>Power:
</TD><TD class=tdat>45.5 hp [33.9 kW]
</TD></TR><TR><TD class=tfld>Cooling:
</TD><TD class=tdat>liquid
</TD></TR><TR><TD class=tfld>Coolant:
</TD><TD class=tdat>10.5 qts [9.9 L]
</TD></TR><TR><TD class=tfld>Compression:
</TD><TD class=tdat>17.4:1
</TD></TR><TR><TD class=tfld>Rated RPMs:
</TD><TD class=tdat>2250
</TD></TR><TR><TD class=tfld>Torque:
</TD><TD class=tdat>121.7 lb-ft [165.0 Nm]
</TD></TR><TR><TD class=tfld>Torque RPMs:
</TD><TD class=tdat>1300
</TD></TR><TR><TD class=tfld>Firing order:
</TD><TD class=tdat>1-2-3
</TD></TR><TR><TD class=tfld>Starter volts:
</TD></TR><TR><TD class=tfld>Oil capacity:
</TD><TD class=tdat>6.5 qts [6.2 L]
</TD></TR><TR><TD class=tfld>Intake valve clearance:</TD><TD class=tdat>0.010 (hot)
0.012 (cold)
</TD></TR><TR><TD class=tfld>Exhaust valve clearance:</TD><TD class=tdat>0.010 (hot)
0.012 (cold)
<TABLE class=tdData3 cellSpacing=0><TBODY><TR><TD class=thdr colSpan=2>Capacity:
</TD><TD class=tdat>10.2 gal [38.6 L]
12.6 gal [47.7 L] (late)
</TD></TR><TR><TD class=tfld>Hydraulic system:
</TD><TD class=tdat>8 gal [30.3 L]
3 POINT HITCH;
<TABLE class=tdData3 cellSpacing=0><TBODY><TR><TD class=tfld>Rear Type:
</TD><TD class=tdat>I
</TD></TR><TR><TD class=tfld>Rear lift:
</TD><TD class=tdat>2,850 lbs [1292 kg]
PTO:
<TABLE class=tdData3 cellSpacing=0><TBODY><TR><TD class=tfld>Rear PTO:</TD><TD class=tdat>transmission
live two-stage clutch (optional)
</TD></TR><TR><TD class=tfld></TD><TD class=tdat>540
540/ground
<TABLE class=tdData3 cellSpacing=0><TBODY><TR><TD class=thdr colSpan=2>Dimensions:
</TD></TR><TR><TD class=tfld>Weight (operating):
</TD><TD class=tdat>3,645 lbs [1653 kg] (diesel)
</TD></TR><TR><TD class=tfld>Wheelbase:
</TD><TD class=tdat>72 inches [182 cm]
</TD></TR><TR><TD class=tfld>Length:
</TD><TD class=tdat>120.6 inches [306 cm]
</TD></TR><TR><TD class=tfld>Width:</TD><TD class=tdat>-unknown-</TD></TR><TR><TD class=tfld>Height:
</TD><TD class=tdat>54 inches [137 cm]
</TD></TR><TR><TD class=tfld>Ground clearance:</TD><TD class=tdat>11.5 inches [29 cm] (differential)
20.5 inches [52 cm] (axle)
</TD></TR><TR><TD class=tfld>2WD turn radius:
</TD><TD class=tdat>9 feet [2.7 m]
</TD></TR><TR><TD colSpan=2> </TD></TR><TR><TD class=thdr colSpan=2>Massey Ferguson 135 Tires:
</TD></TR><TR><TD class=tfld>Ag front:</TD><TD class=tdat>5.50-16
6.00-16
</TD></TR><TR><TD class=tfld>Ag rear:</TD><TD class=tdat>12.4/11-28
13.6/12-28
14.9/13-24
</TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
<TABLE class=tdData3 cellSpacing=0><TBODY><TR><TD class=thdr colSpan=2>135 Serial Numbers:
</TD></TR><TR><TD class=tfld>Location:</TD><TD class=tdat>On the instrument panel below the steering column.</TD></TR></TBODY></TABLE>
<TABLE class=tdData3 cellSpacing=0><TBODY><TR><TD class=thdr colSpan=2>Massey Ferguson 135 Power:
</TD></TR><TR><TD class=tfld>Engine:
</TD></TR><TR><TD class=tfld>Drawbar (claimed):
</TD><TD class=tdat>33 hp [24.6 kW]
</TD></TR><TR><TD class=tfld>PTO (claimed):
</TD><TD class=tdat>38 hp [28.3 kW]
</TD></TR><TR><TD class=tfld>Drawbar (tested):
</TD><TD class=tdat>33.06 hp [24.7 kW]
</TD></TR><TR><TD class=tfld>PTO (tested):</TD><TD class=tdat>37.82 hp [28.2 kW]</TD></TR></TBODY></TABLE>
<TABLE class=tdData3 cellSpacing=0><TBODY><TR><TD class=thdr colSpan=2>Mechanical:
</TD></TR><TR><TD class=tfld>Chassis:
</TD><TD class=tdat>4x2 2WD
</TD></TR><TR><TD class=tfld>Steering:</TD><TD class=tdat>manual
power (optional)
</TD></TR><TR><TD class=tfld>Brakes:
</TD><TD class=tdat>mechanical drum
</TD></TR><TR><TD class=tfld>Cab:</TD><TD class=tdat>Open operator station</TD></TR></TBODY></TABLE>
<TABLE class=tdData3 cellSpacing=0><TBODY><TR><TD class=thdr colSpan=2>Hydraulics:
</TD></TR><TR><TD class=tfld>Type:
</TD><TD class=tdat>-unknown-</TD></TR><TR><TD class=tfld>Capacity:
</TD></TR><TR><TD class=tfld>Pressure:
</TD><TD class=tdat>2800 psi [193.1 bar]
</TD></TR><TR><TD class=tfld>Valve flow:
</TD><TD class=tdat>4.5 gpm [17.0 lpm]
</TD></TR><TR><TD class=tfld>Total flow:
</TD><TD class=tdat>4.8 gpm [18.2 lpm]
</TD></TR><TR><TD class=tfld>Oil type:
</TD><TD class=tdat><TABLE cellSpacing=0 cellPadding=0><TBODY><TR><TD></TD><TD class=oiltyp>MF-1129</TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
<TABLE class=tdData3 cellSpacing=0><TBODY><TR><TD class=thdr colSpan=2>Electrical:
</TD></TR><TR><TD class=tfld>Ground:
</TD><TD class=tdat>negative
</TD></TR><TR><TD class=tfld>Charging system:
</TD><TD class=tdat>generator
</TD></TR><TR><TD class=tfld>Charging amps:
</TD></TR></TBODY></TABLE><TABLE class=tdData3 cellSpacing=0><TBODY><TR><TD class=thdr colSpan=2>Battery:
</TD></TR><TR><TD class=tfld>Number:
</TD></TR><TR><TD class=tfld>Volts:
</TD></TR><TR><TD class=tfld>Amp-hours:</TD><TD class=tdat>
95 (diesel)
