MF 265
<TABLE class=tdData3 cellSpacing=0 width="100%"><TBODY><TR><TD class=tfld>Production years:</TD><TD class=tdat>1975 - 1983</TD></TR></TBODY></TABLE>
<TABLE class=tdData3 cellSpacing=0 width="100%"><TBODY><TR><TD class=tfld>Tractor type:
</TD><TD class=tdat>Farm/Agricultural tractor
<TABLE class=tdData3 cellSpacing=0><TBODY><TR><TD class=thdr colSpan=2>Production:
</TD></TR><TR><TD class=tfld>Manufacturer:
</TD><TD class=tdat>Massey Ferguson
</TD></TR><TR><TD class=tfld>Factory:
</TD><TD class=tdat>-unknown-</TD></TR><TR><TD class=tfld>Total built:</TD><TD class=tdat>-unknown-</TD></TR><TR><TD class=tfld>Original price (USD):
</TD><TD class=tdat>$22,500 (1983)
<TABLE class=tdData3 cellSpacing=0><TBODY><TR><TD class=thdr colSpan=2>Engine:
</TD><TD class=tdat>Perkins
</TD></TR><TR><TD class=tfld>Model:
</TD><TD class=tdat>AD4.236
</TD></TR><TR><TD class=tfld>Fuel:
</TD><TD class=tdat>diesel
</TD></TR><TR><TD class=tfld>Aspiration:
</TD><TD class=tdat>natural
</TD></TR><TR><TD class=tfld>Cylinders:
</TD><TD class=tdat>4
</TD></TR><TR><TD class=tfld>Valves:</TD><TD class=tdat>8</TD></TR><TR><TD class=tfld>Bore/Stroke:
</TD><TD class=tdat>3.875x5.00 inches [98 x 127 mm]
</TD></TR><TR><TD class=tfld>Displacement:
</TD><TD class=tdat>236 ci [3.9 L]
</TD></TR><TR><TD class=tfld>Fuel use:
</TD><TD class=tdat>3.82 gal/hour [14.5 l/hour]
</TD></TR><TR><TD class=tfld>Cooling:
</TD><TD class=tdat>liquid
</TD></TR><TR><TD class=tfld>Coolant:
</TD><TD class=tdat>11 qts [10.4 L]
</TD></TR><TR><TD class=tfld>Air cleaner:
</TD><TD class=tdat>dual dry elements
</TD></TR><TR><TD class=tfld>Compression:
</TD><TD class=tdat>16:1
</TD></TR><TR><TD class=tfld>Rated RPMs:
</TD><TD class=tdat>2000
</TD></TR><TR><TD class=tfld>Starter volts:
</TD><TD class=tdat>12
</TD></TR><TR><TD class=tfld>Oil capacity:
</TD><TD class=tdat>8 qts [7.6 L]
</TD></TR><TR><TD colSpan=2></TD></TR></TBODY></TABLE>
<TABLE class=tdData3 cellSpacing=0><TBODY><TR><TD class=thdr colSpan=2>Transmission:
</TD></TR><TR><TD class=tfld>Gears:
</TD><TD class=tdat>8 forward and 2 reverse
</TD></TR><TR><TD class=tfld>Comments:
</TD><TD class=tdat>Four speeds, plus reverse, with high and low ranges.
</TD></TR><TR><TD class=tfld>Oil capacity:</TD><TD class=tdat>-unknown-</TD></TR><TR><TD class=tfld>Speeds:
</TD><TD class=tdat>With 16.9-28 rear tires.
<TABLE class=tdData3 cellSpacing=0><TBODY><TR><TD class=thdr colSpan=2>Capacity:
</TD><TD class=tdat>18.5 gal [70.0 L]
</TD></TR><TR><TD class=tfld>Hydraulic system:
</TD><TD class=tdat>8 gal [30.3 L]
3 POINT HITCH.
<TABLE class=tdData3 cellSpacing=0><TBODY><TR><TD class=tfld>Rear Type:
</TD><TD class=tdat>II/I
</TD></TR><TR><TD class=tfld>Rear lift:
</TD><TD class=tdat>4,100 lbs [1859 kg]
<TABLE class=tdData3 cellSpacing=0><TBODY><TR><TD class=tfld>Rear PTO:
</TD><TD class=tdat>live (two-stage clutch)
independent (optional)
</TD></TR><TR><TD class=tfld>Rear RPMs:
</TD><TD class=tdat>540
<TABLE class=tdData3 cellSpacing=0><TBODY><TR><TD class=thdr colSpan=2>Dimensions:
</TD></TR><TR><TD class=tfld>Weight (shipping):
</TD><TD class=tdat>6,100 lbs [2766 kg]
</TD></TR><TR><TD class=tfld>Weight (operating):
</TD><TD class=tdat>6,385 lbs [2896 kg]
</TD></TR><TR><TD class=tfld>Weight (ballasted):
</TD><TD class=tdat>8,200 lbs [3719 kg]
</TD></TR><TR><TD class=tfld>Wheelbase:
</TD><TD class=tdat>82 inches [208 cm]
</TD></TR><TR><TD class=tfld>Length:</TD><TD class=tdat>-unknown-</TD></TR><TR><TD class=tfld>Width:</TD><TD class=tdat>-unknown-</TD></TR><TR><TD class=tfld>Height (hood):
</TD><TD class=tdat>63.1 inches [160 cm]
67.3 inches [170 cm] (row-crop)
62.1 inches [157 cm] (low-profile)
</TD></TR><TR><TD class=tfld>Ground clearance:
</TD><TD class=tdat>16 inches [40 cm]
18.4 inches [46 cm] (row-crop)
14.9 inches [37 cm] (low-profile)
</TD></TR><TR><TD class=tfld>Front tread:
</TD><TD class=tdat>48 to 72 inches
[121 to 182 cm]
52 to 76 inches (row-crop)
132 to 193 cm
</TD></TR><TR><TD class=tfld>Rear tread:
</TD><TD class=tdat>56 to 90 inches
[142 to 228 cm]
55 to 87 inches (low-profile)
139 to 220 cm
</TD></TR><TR><TD class=tfld>2WD turn radius:
</TD><TD class=tdat>12 feet [3.7 m]
</TD></TR><TR><TD colSpan=2></TD></TR><TR><TD class=thdr colSpan=2>Massey Ferguson 265 Tires:
</TD></TR><TR><TD class=tfld>Ag front:
</TD><TD class=tdat>6.00-16
6.50-16
7.5L-15
</TD></TR><TR><TD class=tfld>Ag rear:
</TD><TD class=tdat>16.9-24
16.9-28
16.9-30
18.4-26
</TD><TD class=tdat>6.50-16 (row-crop)
7.5L-15 (row-crop)
6.00-16 (low-proflie)
6.50-16 (low-profile)
7.50-10 (low-profile)
9.5L-10 (low-profile)
</TD><TD class=tdat>13.6-38 (row-crop)
14.9-38 (row-crop)
15.5-38 (row-crop)
18.4-30 (row-crop)
14.9-24 (low-profile)
16.9-24 (low-profile)
18.4-16.1 (low-profile)
21.5L-16.1 (low-profile)
<TABLE class=tdData3 cellSpacing=0><TBODY><TR><TD class=thdr colSpan=2>265 Serial Numbers:
</TD></TR><TR><TD class=tfld>Location:
</TD><TD class=tdat>Below instrument panel
</TD></TR><TR><TD class=tdat colSpan=2>1974: 9A202190
1975: 9A207681
1976: 9A232539
1977: 9A254045
1978: 9A276935
1979: 9A296946
1980: 9A326169
1981: 9A339343
1982: 9A350584
1983: 9A354679
<TABLE class=tdData3 cellSpacing=0><TBODY><TR><TD class=thdr colSpan=2>Massey Ferguson 265 Power:
</TD></TR><TR><TD class=tfld>Drawbar (claimed):
</TD><TD class=tdat>50 hp [37.3 kW]
</TD></TR><TR><TD class=tfld>PTO (claimed):
</TD><TD class=tdat>60 hp [44.7 kW]
</TD></TR><TR><TD class=tfld>Drawbar (tested):
</TD><TD class=tdat>50.38 hp [37.6 kW]
</TD></TR><TR><TD class=tfld>PTO (tested):
</TD><TD class=tdat>60.73 hp [45.3 kW] </TD></TR></TBODY></TABLE>
<TABLE class=tdData3 cellSpacing=0><TBODY><TR><TD class=thdr colSpan=2>Mechanical:
</TD></TR><TR><TD class=tfld>Chassis:
</TD><TD class=tdat>4x2 2WD
</TD></TR><TR><TD class=tfld>Differential lock:</TD><TD class=tdat>foot-pedal
</TD></TR><TR><TD class=tfld>Steering:
</TD><TD class=tdat>hydrostatic power
</TD></TR><TR><TD class=tfld>Brakes:
</TD><TD class=tdat>differential mechanical WET disc
</TD></TR><TR><TD class=tfld>Cab:
</TD><TD class=tdat>Open operator station. Two-post ROPS optional. Cab optional.
<TABLE class=tdData3 cellSpacing=0><TBODY><TR><TD class=thdr colSpan=2>Hydraulics:
</TD></TR><TR><TD class=tfld>Type:</TD><TD class=tdat>-unknown-</TD></TR><TR><TD class=tfld>Capacity:
</TD></TR><TR><TD class=tfld>Pressure:
</TD><TD class=tdat>2300 psi [158.6 bar]
</TD><TD class=tdat>0 to 2
</TD></TR><TR><TD class=tfld>Valve flow:
</TD><TD class=tdat>10 gpm [37.9 lpm]
4.5 gpm [17.0 lpm] (3-point)
</TD></TR><TR><TD class=tfld>Total flow:
</TD><TD class=tdat>19.5 gpm [73.8 lpm]
</TD></TR><TR><TD class=tfld>Steering flow:
</TD><TD class=tdat>5 gpm [18.9 lpm]
</TD></TR><TR><TD colSpan=2></TD></TR><TR><TD class=thdr colSpan=2>Electrical:
</TD></TR><TR><TD class=tfld>Ground:</TD><TD class=tdat>-unknown-</TD></TR><TR><TD class=tfld>Charging system:
</TD><TD class=tdat>alternator
</TD></TR><TR><TD class=tfld>Charging amps:
</TD><TD class=tdat>37
</TD></TR><TR><TD colSpan=2></TD></TR><TR><TD class=thdr colSpan=2>Battery:
</TD></TR><TR><TD class=tfld>Number:
</TD></TR><TR><TD class=tfld>Volts:
</TD></TR><TR><TD class=tfld>Amp-hours:
</TD><TD class=tdat>95
