I've done a project on my lancer as well but I used an ihi turbo without intercooler I was running my car at 6 psi and the result was abt 140 bhp it was as fast as an 1.8 civic but good fun
Correct me is I am wrong, but CT12 was designed for a 3.0 Ltr engine and is a bigger turbo. That would mean it would spool at much higher RPM for a 1.3 Ltr engine as compared to a CT9. Wouldn't that make it a b***h to drive?
nice....now u should just replace the 1.3 block with 1.6.....they both use the same head i am told!
Well You Are Half Correct....Yea CT12 Came In 3.0L Engine But As TwinsCT-12 x 2
Will think about it also in near future.
Nice stuffs & nice project too ... !
sheikh sab, where the video of 0 to a 60 in 4.5
mind it (miles)
I would say you should go for a ct9 since ppl upgrade 4eft to ct9 as well
and + u cannot go more then 10 psi on stock internals so its better u go for a ct9
for how much did u get the injectors for
any updates
Injectors are 210CC original Mitsubishi no alterations required. I bought these injectors from Wasay.
InshAllah will give you more updates soon. With the current setup I am running at 0.7Bar now. Will retard some timing and will boost more power.
Bhai jaan I will post the video you convert the speed into miles on your own and do let me know also
@ahad89where are you these days bro.Ahmeds Lancer has MashaAllah has boosted more then both of us.Rest he will tell you better wht happend with him hahaha it wasnt tht easy for him like Amir bhai made for us MashaAllah
ok thats great ...cuz i have something like that for my car in future ..so yr project is very important to me.....best of luck with running
Ahmed Is Still Struggling A Bit But MOST Of Things Are Sorted Out....!!And Car Is Performing Well Enough...!!Till I Know.....Any Swapped Or Stock D With Mild Mods Got No Match With His Car !Have Driven It Once When Its Having Low Boost And Its Responding Quiet Well...!!Thats Due To CT-9....!! LOw End Got Too Responsive With This Baby Turbo !!
farrukh bhai plan banayen na kisi din mulaqat karate hain dono ct9's ke
hey buddy nice project.....i had lancer 1.6 glx 2005 n was using 50 shots nitrous......btw do u need lowering springs??
@WassayYes but learned many things to sort out. Planing to swap CT9 with TD04.
