AoA Dear MOVE'ers,
Hope you are all keeping safe and healthy.So, I jump-started my MOVE 2015 this morning. Being a second car and due to lockdown it wasn't in use for quite some time. After a few attempts it started and I took it for a short drive. It's showing these alert lights and the brakes also felt some friction.Need your expert advice and guidance, please. I'm especially worried about engine check light.
Regards,
Asim
Take -ve terminal off for few minsRe connect startIf it re appears go to a workshop which has scanning tool
Thanks @hash4u for your quick response. will try this, however, i've read at some other forums that you need to run scanner diagnostics by some expert mechanic.
Of course scanner tool will be reqd. to be run by its expert, still, 1st try to do what Hashim Bhai has suggested.
Disconnect for at least half an hour and then reconnect. I am quite hopeful your issue will be resolved. IN SHA ALLAH.
AoA Forgot to update earlier, just removing battery terminal for a while and reinstalling helped clear the alerts
W.S.
Good to know that your issue got resolved.
GOD Forbid, if any alert, or these alerts pops up again, then have your vehicle scanned via OBD Scanner from some expert.
