Avenger 8x8 750 EFI
Load Capacity on Water
1000 lbs / 454 kg total
Engine
4 cycle OHV V-Twin gasoline engine, electronic ignition, full pressure lubrication and oil filter, 3 year warranty
Model
Kohler Aegis LH 775
Horsepower
31
Displacement
748cc
Cooling
Liquid Cooled
Starting
Electric
Brakes
Hydraulic
Steering
One-piece ergonomic handlebar steering control with mounted brake lever and parking brake. For safety and ease of handling, the ARGO steering transmission provides continuous torque to all axles.
Controls
Right-hand twist grip throttle. Light switch and ignition switch.
Clutch & Transmission
Belt-driven,Continuously Variable Transmission (CVT) maximizes engine power to the transmission with high and low range forward, neutral and reverse, compactly housed with an efficient planetary differential.
Drive System
Roller chains drive machined sprockets that are spline-fit onto 1.25" diameter axles.Bearings are greaseable and are protected with double-sealed outer flange assemblies.
Frame
Formed steel channel construction,welded for high strength and durability. Polyester powder coated for lasting protection.
Body
Vacuum formed High Density Polyethylene (HDPE)
Full Skid Plate
Standard
Load Capacity on Land (without accessories)
1150 lbs / 521 kg total. No restrictions for rear compartment
Towing Capacity
1800 lbs / 818 kg
Seating Capacity
6 persons on land, 4 persons on water
Fuel Capacity
7.1 US Gallons (27 litres). See-through polyethylene fuel tank. 8 hours of operation.
Speed (on land)
20 mph / 32 km per hour
Speed (on water)
2.5 mph / 4 km per hour
Shipping Weight
1250 lbs / 570 kg
Axle Bearing Extensions
Front- Standard...Rear- Standard
Hourmeter
Standard
Voltmeter
Standard
Temperature Gauge
Standard
Low Charge Rate Light
Standard
Low Oil Pressure Light
Standard
Tire
Goodyear Rawhide III AT25 x 11.50-9 NHS
Ground Pressure
2.1 psi (14.5 kPa) using tires, 0.67 psi (4.6 kPa) using tracks
Operating Conditions
All weather,all-terrain,-40°C to +40°C
