i am selling Top natch Alpine iDA-X305 Digital Media Receive for sell
i had this unit in my civic but i sold my civic, sound is mind below:-
Import from USA, FINAL PRICE IS RS 19000. contact #03456031977 or pm me
Alpine Electronics of America, Inc.
specification:-
Features and Specification
SPECIFICATIONS
CEA-2006 Power Ratings
CEA-2006 Power Rating: 4 I? @14.4 V Ƈ%THD+N, S/N 80 dBA (ref.1 W into 4 I?), 18 W x 4
Max Power Output Ratings
Max Power Output: 50W x 4
FM Tuner
Tuning Range: 87.7-107.9 MHz
Mono Usable Sensitivity: 9.3 dBf (0.8 A?V/75 ohms)
50dB Quieting Sensitivity: 13.5 dBf (1.3 A?V/75 ohms)
Alternate Channel Selectivity: 80.0 dB
Signal-to-Noise (S/N) Ratio: 65.0 dB
Stereo Separation: 35.0 dB
Capture Ratio: 2.0 dB
AM Tuner
Tuning Range: 530-1,710 kHz
Usable Sensitivity (IEC Standard): 22.5/27.0 (A?V/dB)
Connection for iPodA?
USB Requirements: 1.1/2.0
Max. Power Consumption: 500 mA
USB Class: Mass Storage
File System: FAT 12/16/32
MP3 Decoding: MPEG-1/2 AUDIO Layer-3
WMA Decoding: Windows Media' Audio
AAC Decoding: ACC-LC format ''/m4a'' file
Number of Channels: 2-Channel (Stereo)
Frequency Response: 5-20 k A?1 dB (Frequency Response may differ depending on the encoder software/bit rate)
Total Harmonic Distortion: 0.008% (at 1 kHz)
Dynamic Range: 95 dB (at 1 kHz)
Signal-to-Noise Ratio: 105 dB
Channel Separation: 85 dB (at 1 kHz)
Sound Tuning
Subwoofer Level Adjustment: 0 to 15
High Pass Filter: OFF/80/120/160Hz (Selectable)
Bass Level Control Range: A?14
Bass Center Frequency: 60/80/100/200Hz (Selectable)
Bass Band Width Adjustment (Q): 4 choices (2 =narrow, 1 =wide)
Treble Level Control Range: A?14
Treble Center Frequency: 10/12.5/15/17.5kHz (Selectable)
Remote Control
Remote Control: Not Included
Model Number: RUE-4202
Battery Type: AAA Batteries (2 pcs.)
Weight: 50 g (1.8 oz.)
Dimensions
Din Size: 1
Chassis Size (W x H x D) mm: 178 mm x 50 mm x 156 mm
Chassis Size (W x H x D) in: 7'' x 2'' x 6-1/8''
Nose Piece Size (W x H x D) mm: 170 mm x 46 mm x 28 mm
Nose Piece Size (W x H x D) in: 6-7/8'' x 1-13/16'' x 1-1/8''
General
Power Requirement: 14.4 (11-16) V.DC
Pre Output Voltage (Before Clipping): 2 V
Operating Temperature (A?C/ A?F): 60 A?C (140 A?F) to -10 A?C (14 A?F)
Maximum Mounting Angle: 35A? from Horizontal
Weight: 1.0 kg (2 lbs. 3 oz.)
FEATURES
Tuner
Memory Presets: Preset Stations (FM:12 / AM:6)
Memory: Auto Memory
Seek Mode: Local / DX Selection
HD RadioA?
Built-In or Ready: Built-In or Ready HD Radio' Ready
Connection: Alpine TUA-T500HD / TUA-T550HD Required
Signal Switching: Automatic Digital / Analog
Multi-Casting: Multi-Cast HD1,HD2,HD3
Supports iTunesA? Tagging: Supports iTunesA? Tagging (TUA-T550HD Required)
BluetoothA?
Parrot Bluetooth Module Built-In: Built-In or Ready Parrot Bluetooth Ready
Connection: Alpine KCE-400BT Required. Features may differ between phone model and service providers.
Hands Free: Hands Free Calling
Phone Book: Phone Book Transfer
Adjusting the volume when receiving a Call: Adjusting the volume when receiving a Call
Streaming Music: Streaming Music Playback
Redial Function: Redial Function
Streaming Music Control: Streaming Music Control
Call History (Dialed, Received, Missed): Dialed, Received, Missed
Voice Dial Operation: Voice Dial Operation
Works with iPhone: Works with iPhone
Connection Type: USB Connection
Connection for USB: Dedicated iPodA? Source
Connection: USB Cable Included
Compatibility for iPodA?/iPhoneA?: iPodA? Compatibility iPodA? 5th generation, iPodA? nano 1st/2nd/3rd/4th generation, iPodA? classic, iPodA? touch 1st/2nd generation
M.I.X. (Shuffle) Capability: Song, Albums, All
Music Control: Up / Down / Repeat
Available Selections: Playlist, Artist, Album, Song, Podcast, Genre, Composer, Audiobook
Percentage Search: Percentage Search
Alphabet Search: Alphabet Search
Information Display: Album Art, Song (Title, Album), Clock
Easy Navigating: Quick Search with Double-Action Encoder and Back Button for Easy Menu Navigation
Connection for USB
USB Connection: USB
USB Input: Back-Side
Connection: USB Cable (Included)
Music Playback: MP3/AAC/WMA Playback
Satellite Radio
Built-In or Ready: Built-In or Ready Satellite Radio Ready
Connection: SIRIUS or XM Adapter Required
Satellite Provider Capability: SIRIUS or XM
Preset Memory: 3-Bands (6 Per Band, 18 Channels Total)
Easy Navigating : Quick Search
Music Information: Category, Artist, Song
Portable Compatibility: SIRIUS Plug N Play Devices (Adapter Required)
Sound Tuning
Subwoofer Level: Subwoofer Level Adjustment
High Pass Filter: High Pass Filter Adjustment
Equalizer: Equalizer 5 Band Graphic / 7 Band Parametric Equalizer Ready (PXA-H100 Required)
Bass Level: Bass Level Adjustment
Bass Center Frequency: Bass Center Frequency Adjustment
Bass Bandwidth Adjustment: Bass Width Q Adjustment
Treble Level: Treble Level Adjustment
Treble Center Frequency: Treble Center Frequency Adjustment
Loudness: Loudness Feature
MediaXpander: MediaXpander Ready (PXA-H100 Required)
Time Correction: Time Correction 6 Channel Time Correction Ready (PXA-H100 Required)
Crossover: Crossover Ready (PXA-H100 Required)
IMPRINT: IMPRINT Sound System Ready (PXA-H100 Required)
CD Changer Control
M.I.X.: One/All (Shuffle)
Multi-Changer Control: Multi-Changer Control including MP3 Changer CHA-S634 (with KCA-410C)
Music Text Information: CD:Text Scroll Display, MP3: Text Information Display (ID3 Tag)
Music Control: Play/Pause/Forward/Backward
Repeat: Song/Disc
General
Power Output: Max 50 W x 4 High Power Amplifier
CD Changer: CD Changer Control
Display: 2.2'' High Resolution TFT Color Display
Control Type: Double-Action Encoder
iPersonalize: iPersonalize (Wallpaper Only)
Face Color: Black
Illumination Buttons: Blue / Red Illuminated Buttons
PreOut: 3 PreOuts (2 V )
DAC: 24-Bit Burr-Brown DAC
Auxiliary Input: Versatile-Link Ready (KCA-121B Auxiliary Input)
Steering Wheel Control: Steering Wheel Control Ready
Selectable Power Input: 2 PreIn (Front / Rear)
Bass & Treble: Bass & Treble Controls
Fader & Balance: Fader & Balance Controls
Clock: Built-In Clock
Calendar: Built-In Calendar
DIN Trim Plate: Detachable Trim Plate
Detachable Face Plate: Detachable Face Plate
Dimmer: Dimmer Input
Power Antenna Lead: Power Antenna Lead Output
Remote Turn-On: Remote Turn-On Output
Audio Interrupt: Audio Interrupt Input
Remote Control: Remote Control Ready
