i placed my Bid on an Alpine Amp today which is Alpine Mrv f450 its a 4 channel amp its not brand new if someone knows about amps and i mean proper amps the owner has aggreed on £100 so the question is
IS Alpine Mrv f450 worth £100 or no or should i go for Option no 2which is Alpine Mrv F300 for £35
Sir
F450 worths around 200 pounds new, I do not know about your system but I think F300 would be more suitable if you do not have high end system and 75W are enough for you on all 4 corners.
Since you are getting it in 3 times less money.
Regards
I am using Diamond audio HEX 600 component speakers i bought em brand new almost year and half ago for 400 pounds and as sub i am using a JBL orignal enclosurei used legacy steel before which was quiet powerful but it did not do the trick as it was a low power 4 channel amp today i found another amp which is ALpine Mrv f-540and he is asking for 140 pounds is that worth it or should i try something different
you have really nice speakers, real powerful.
MRV 450 would be a good companion, your speakers can take on double the power though.
140 pounds is a decent price for F450, just check it properly, if it is working fine.
regards
