@iamadee, umer91 & all others who are facing any RPM issue on GLI/XLI
This thread is not about the RPM issue common on XLI/GLI. It is about a certain RPM behavior on a 1800cc Altis Cruisetronic (triptronic transmission) which is completely different from what you guys face on GLI/XLI . I have confirmed from various sources including Toyota mechanics, other Pakwheelers testimonials, and test driving another Altis cruisetronic that this behavior is not an anamoly and is due to electronic throttle.
If any of the GLi/XLi owners are facing any RPM issue, it is an electronics issue and can be solved by a bigger battery OR better grounding. Also whenever you get your throttle body serviced, get the ECU reset.
@all
The following work was done on my Altis today at 40k maintenance
1)Engine Tune up & Diagnostic using OBD (also commonly known as IT or computer)
2)Spark plug change
3)Air filter Change
4)ATF Chamber & ATF Filter Service
5)ATF replaced with ATF-WS 4L (as per manual and markings on stick)
6)Toyota Injector Cleaner
5)Engine Oil replaced with Mobil 1 4L Fully synthetic + Oil filter replaced
6)Rear brake Pad service
7)New Front brake pads
8)Coolant replaced with Toyota Coolant
9)Brake Oil changed
10)Cabin A/C Filter service
11)Throttle Body service
Total cost was 27k and add 4k for Full tank of Hi-octane so total amount spent today was 31k. If you think any other maintenance work is required do let me know
@Jz
Yar thanks for your time today. I asked Toyota guys but Altis does not has any fuel pump. Instead it has some suction pump sort of thing like on mark x and is to replaced only after 100,000km
