PakWheels Team,
I recently purchased Alto Lapin 2015 - Chocolat Edition.
The car worked fine for few months but after few months whenever i would start the car and put it on R or D or L the car won't move acceleration would would go away too but after 10 seconds the gear will engage and the car starts moving then the drive is fine , i got it checked and gear oil was not sufficient so i got the gear oil changed and then the issue never appeared.
Now 2 months later the same issue happened, start the car wait for 10 seconds and engage the gear and it will engage and will work. Only to later find out the Transmission Temperature Warning on dashboard which revealed that the Electric Oil Pump is not functioning fine.
I am based in Karachi, few of the mechanics are suggesting to get the Transmission replaced costing me around 40k to 50k.
Really need your help as to how to overcome this issue or suggest a good mechanic who deals in Japanese and knows what he is doing instead of fixing 1 thing and then messing up the other.
