Get your thermostat checked or install aftermarket thermostat on same wiring dont allow electrician to alter wires just buy ac thermostat from ac shop for 250rs give it to electrician pay him 150rs for this job he will join two wires with it and the metal wire will go to the ac evaporator box below dash on passenger side...
Secondly turn on your ac and the wire going from ac compressor checked that if its damaged from any connector by moving it while ac is on if it trips than you can get that connector replaced, check whole wire till the fuse box, get this checking sone before installing thermostat.
The aftermarket thermostat has a knob to control temperature...
Dont allow ekectrician to alter wiring if he is doing so he is just doing to destroy your wiring and for extra labour... Get that done if front of you. Also check the ac relay in the relay box beside battery.
