Kindly Give Viable Suggestions
TS-E2090
Specifications are as follow
TS-E2090 (Archived) - Pioneer Europe
Specifications
<TABLE class=datatable><TBODY><TR><TH>Features</TH><TH>TS-E2090</TH></TR><TR><TD>Frequency response</TD><TD>25-32,000 Hz</TD></TR><TR><TD>Sensitivity (1W/1m)</TD><TD>91 dB</TD></TR><TR><TD>Maximum Power</TD><TD>250 W</TD></TR><TR><TD>Nominal input power</TD><TD>90 W</TD></TR><TR><TD>Woofer size (cm)</TD><TD>20 cm</TD></TR><TR><TD>Woofer material</TD><TD>Metal coated IMPP cone</TD></TR><TR><TD>Midrange size (mm)</TD><TD>57,0 mm</TD></TR><TR><TD>Midrange material</TD><TD>PPTA cone</TD></TR><TR><TD>Tweeter size (mm)</TD><TD>12,0 mm</TD></TR><TR><TD>Damper type</TD><TD>Large diameter Conex damper</TD></TR></TBODY></TABLE>
