And BTW The Way You ARe ADJUSTING THEM..........If The Correction Factor Goes Like That In Double Figure The CEL Is Thrown And ECU Simply Goes In LIMP MODE Detecting That Something Is Wrong Which Is Compensating So Much Fuel Changes....
I Ask You This QUESTION 1000 TIMES What Do You HAVE To To Adjust AFR's On Perticular Revvs And How You Set The Threshold ...!!
The AFR's Will SIMPLY Go Out Of Senses On High Revvs If You Adjust Them For Lower Revvs And WIll Go OUT On LOW If Set For High REVVS.....!!! Whatever SIgnal Changes You Made ...They Will Be Fixed For That Particular Condition And As Condition Changes...Things Changes Quiet Some....! For Making It Stable On All Revv Ranges....YOU NEED A THRESHOLD FOR Every 1000rpm Range Like PIGGYBACKS Have....!!
