Small sized Anti GPS Tracking Device powered by and for use with any car that has a standardCigarette Jack for power and supplys 12V .
Operation is incredibly easy, as all it take to work is plugging it into the cigarette lighter and it's on and working!
The Anti-Tracker will knock out GPS logging or GPS tracking systems that may be operating on your vehicle. Using our Anti-Tracker will make it very hard for any one to keep tabs on you or your vehicle.Can easily be made portable when car is parked by placing in car mobile jump starter/charger/air pressor. This device will block all GPS signals and makes it impossible for big brother to track your movements.
It can affect RFID Chips in close range so be warned.Mobile GPS signal jammers may not be permissable to import into certain countries due to licencing of broadcasts or other restrictions.
This item is permitted to members of security services, FBI, CIA and various government licenced agencies.
Operating band: 1350 to 1700Mhz
Signal Stealth Power: 210m W
Antenna Impedance: 60 w
Coverage Area: 4-7 Meters
Power supply: 12V
Currency: 210mA
Dimension: 201x106x36mm (LxWxD)
Manufacturer and Origin: Japan
This item is not available anywhere else and is strictly for use by Goverment Agencies. So if you have a expensive car on finance with a tracker fixed then you know btter than mewha you can do with it. I have a contat through which i can get hold of thi device. THE PRICE FOR THIS LITTLE DEVICE IS £600.
Don't scream about price, first try and find the maker of this then try and import it.
