Reply By : geforce on 5/17/2009 10:55:38 PM
so their is only one way to change pre ,
i am using jbl gto936e , on that vocal is low , treble is low , i have extra set of tweeters to raise treble level , yaar kuch na kuch to hoga , jo kaam power per ziada volume day ?
i mean sensivity ziada ho
mostly pioneer pre have less mid. unlike alpine. they have better mid. gto936e has the worst mid range quality.
Reply By : shaheel_shael on 5/18/2009 7:34:03 PM
Enerlevel:wat abt my query???
sorry i missed ur questioin , plz type ur question again and i will for sure help.
Reply By : doubletrouble on 5/18/2009 9:34:34 PM
heya....i have kenwood kdc-mp339 pre.......some selenium base speakerx..bot from abroad a long tym ago but works finefew days back i purchased blue laser amp 1500W for arount 4.5K .....all this is working prety finenow the shopkeeper gave me the advice of installing pioneer D2 sub-woofer.....is it Oi just want a very normal system......bot amp from a reliable source, in case of any problem hel exchange... so i dun have problem vid chinese blue laser amp...any other options..for woofer......and should i change the head-unit or is it fine....
u have not mentioned if this blue lacer is 4 channel or 2?. if its 4 then u can get d2. if its 2 then u need to get another amp.
Reply By : scorpion80 on 5/20/2009 8:16:09 AM
Hi..
Question.
Does preout voltage really matter ? as far as i know it increase sound clearity .. m i right ?
Do u recommend pioneer 4150ub . ? if not recommend any in this range
just only helps u to remove some unwanted whining noise from the car. altho in real world , u need a dogs ear to know the difference between 2 - 4 volt. however i am very choosy about this. i would take 4 volt minimum so i could remove off the engine noise if it occurs.
Reply By : kamukamu on 5/21/2009 4:51:47 PM
guys heres the dillema.i need a pre so im getting a pioneer pre worth 9 10 k but i saw a chinese dvd player with screen and usb an all that stuff for 16 kso im confused ...shoud i go 4 da chinese..i mean are chinese products good on soung quality and reliable???need help
no chinese players dont have quality. but they do work for a while if properly used.
