1.cannot easily pass acca, there are 14 exams in total (3 arts)
If you pass all exams in 1st attempt, you can do acca in 2 1/2 years...and next 3 years you do internship.
Dont need to do CAT to do Acca but it is best route to go (at least i did), you will have a strong base and you get test exemption is acca. basically if you do CAT, you will be exempt from acca part 1 (3 tests) so only take 11 more exams to do acca (starting from 2.1, exemption is 1.1, 1.2, and 1.3)
acca is equivalent to CA.
CA has 6 modules total : A, B, C, D, E, F
If you pass ACCA, you are exempt from A, B, C, D.
When you go to acca internship for next 3 years, you can take internship with CA and take modules E and F.
SO YOU WILL HAVE BOTH ACCA AND CA DEGREES!!!
Time taken for CA on passing FIRST ATTEMPT EVERY PAPER:
2 years study modules (A, B, C, D) + 3 1/2 years of internship and pass modules (E, F) =5 1/2 years YOU HAVE CA DEGREE
Time take for ACCA (2 1/2 years) + only 3 years internship which you can also do CA modules (E + F)= 5 1/2 years BOTH ACCA AND CA DEGREES!!!
Dont expect to get paid allot in pakistan with just ACCA...CA has monoply in paki.
ACCA is good international...it is like a "brand" name...employment in over 140 countries...
avg STARTING SALARY for acca is 20,000 (my principle told me) while CA is 50-60k so no value for acca in pakistan.
