You can't replace them. Integrated LED headlamp assemblies do not have replaceable bulbs. If you ever need to, you will need to replace the entire Headlight assembly, which typically would cost you around PKR 3-4 lac, and even then you will get the exact same unit that can be recognized by the headlight controller and bus.
