head ki seal leak hogai hain.
Sent from my SM-N900 using PW Forums mobile app
Ok means i just need to change the seal..how much it will cost and is there any good or bad quality?
Sent from my SPH-L720 using PW Forums mobile app
Is your bike honda or chonda ?
Chonda road prince
looks like your head cylinder gasket is leak go to a good mechanic and buy a good quality gasket as its chonda i am not sure that hondas gasket will work or not .Anyway I think whole process is going to cost around 500rs depending on mechanic
Oh no thats costly...btw i will go to mechanic tommorow
Ok so i went to mechanic he didnt change the gasket he changed only the rubber of valve(tappet).Is he doing right?
Do you have pics more pics of it leaking oil? It might be due to that seal.
If it happens again share more pics.
Sent from my Nexus 5 using Tapatalk
alright i will inform if it leaks again in few days
It doesn't look like that the tappet cover is leaking oil in above pic well do share the results
so guys the mechanic was right no oil leakage after that.now i can drive without tension
Sent from my SM-G531H using PW Forums mobile app
