[INDENT] SPECIFICATIONS:
General
Length: 218.5 inches
Width: 100 inches
Height: 99.25 inches
Combat Weight: 12.5 Ton
Weight, curb: 10.6 Ton
Personnel Capacity: 13
Fuel Tank Capacity: 390 lit
Amphibious Condition: Yes, free board - 18 inches
Cruising Range: 320 miles
Nominal Ground Pressure: 7.79 psi
Number of Shoes: 67 left side, 68 right side
Powerpack (Two Options):
Option 1 - Detroit Diesel 6V53T
Type: Two Stroke Cycle
Fuel: Diesel
Rated Power: 275 HP
Power to Weight Ratio: 22 HP/Ton
Transmission:
Make & Mode:l Allison TX 100-1A
Type Automatic: 3 Speed
Steering: Differential or Pivot Brake
Pivot Brake Type: Disc
Option 1 - UTD-20
Type: Four Stroke Cycle
Fuel: Diesel
Rated Power: 330 HP
Power to Weight Ratio: 25 HP/Ton
Transmission:
Make & Model: Hydro Mechanical
Type: Mechanical, 6 F, 1 R
Steering: Planetary
Optional
Firing Ports: Available
Periscope for Crew: Available
APC Factory Heavy Industries Taxila (HIT) Specifications
[/INDENT]
