Dear pakwheelers,I recently have bought aqua'14. I was too excited with the overall experience but suddenly after a body wash following wheel allignment, the ac stopped working if set at any temp other than LOW. the fan is blowing hot air even if the temperature is settled at 23 (routine). I tried to google it but nothing useful found in the solutions but yes found the same complaint from various owners in different parts of the world. PS: i fear mechanics.Does anyone faced this issue or can diagnose it?This is the link for the same problem from US. https://priuschat.com/threads/ac-only-blows-cold-when-temp-is-set-to-lo.187696/
have you ever used a car with climate control previously?
if your ambient temperature is lower then set temp of the cluster the AC WILL NOT START....at LOW only its turns on regardless of ambient temperature.
Yes. Used the climate control previously in move but never experienced this even in winters. It was in my mind but it was warm yesterday in karachi and eventually i had to keep it on the low with manually ajduated blower speed. but let me recheck it as karachi is in its lowest temperature these days.
post a picture of your settings
Its the standard setting, just push the auto button. Temp set at 23.5 and let the climate control do what it does. But its all fine now. Ac working perfectly. Might be the moisture after wash.Thanks
Can you call me please 03135355932
