You can not be helped. Kindly ask your ORIGINAL question to some forum else.
If your AQUA is a thumb-start (aka push start), where u press a button only and the engine starts, then YES your car has immobilizer. If you have a keyhole and u insert a key into it, turn to ACC, then ON, then IG and it fires up the engine, and your key is a plane naked metal key without anything black, or plastic, on it; then BRO YOU HAVE NO IMMOBILIZER.
Doesn't matter what package or class of a certain model; immobilizers are either fitted or not. The only cars in which Immobilizers are STANDARD all thru are cars that come fitted with thumb-start aka push start, aka smartkey.
If this answer don't satisfy you, BRO YOU CAN NOT BE HELPED
