Oh so sorry just remembered had to reply.
Step 1: Wash- by spraying water thoroughly if you don't have a pressure washer (I personally don't use) once thoroughly watered dip a MF in a bucket with Meguiars Wash and Wax Shampoo, wipe clean with shampoo and wash off again.
Step 2: Dry with a separate MF.
Step 3: Apply Meguiars Gold class wax
Step 4: Remove with another separate MF
The above 4 steps ideally should be repeated once a month at least to keep your car glossy and minimum debris/spotting attractive
For tyres, use a good detergent with soft bristled brush and when clean, coat with CarPro Perl 1:3-1:5 (1 being Perl and 3 or 5 parts water as per your glossiness liking)
In the meanwhile between weekly or monthly waxes, If car normal dusty, spray water, use wet MF and wipe dry. If its too dirty use Shampoo.
Never ever do dry dusting or even damp dusting. Let it stay dirty if not enough time to wash it properly.
Since your color is a dark metallic therefore recommended products are Gold Class range. Do keep a separate MF for each purpose. Don't ever mix MF meant for one job to use for another. If possible get it Sealant coated once from a professional to bring the perfect gloss of your paint and then keep following the cleaning procedure suggested. Sealant coatings cost 10k-15k max depending on the detailer charges.
For interior use Meguiars Interior Dressing.
