The thermostat is set to full. Still this problem exists.
xulfiqar bhai can u please help me where should i take my car for overhauling the engine of cultus. And tell me any mechanic who can perform compression test , engine vaccum check and oil pressure check!
Which car is it? Accord?
accord CL7
@afnan.bashir
MICU is part of the underhood fuse box and i believe the whole needs to replaced if faulty. My advise would be to swap it with another one and check, if issue remains then atleast you know that your MICU is fine :). I think CL7/CL9 share the same box but I might be wrong.
Yes will do the same but first i have to do Relay Control Module Input test. and verify wiring. After that i suspect MICU is gonner. @xulfiqar why these codes are different like Alarm Message written at end? once module lost communication it lost it. how can it be possible it lost communication for alarm but works for other? can you help me understand difference in following codes
I Googled Nipolex coolant and no coolant like thing appeared. I always use Abro coolants. Google Abro coolants and you will see tons of images. Nipolex you bought isn't even on the internet. You should have Googled before pouring it in your car. You should have thrown the bottle of that coolant on the face of the person who sold you colored water. I was make sure stuff i buy is original if i want original. Attaching picture i took of the coolant i bought.
AoaI want to buy my first car. I need suggestions and help from u guys specially from xulfiqar.My range is 7.5 llakhs. I need a vehicle which fuel friendly and economical As I am military personnel so I may travel once in a month on motorway for my home.I ll be requiring suggestions and views on daihatsu terios kid too.
a few questions is it ready to use (pre diluted) ?how many liters ?How much $$$ ?and lastly from where did you buy it ?
Yup pre diluted. It's 1 gallon. Price is 550 and available at Auto Pharmacy at main Plaza. I have used the red one. It's nice. But this one seems better. Red one is for newer cars.
Products - Automotive - Radiator / Cooling System Fluids - ENGINE COOLANT GREEN | ABRO Industries, Inc
thanks manso i should use the green one in my car (1995)
Google shows Osaka too.......... useless IMO. It depends on you that was my old car so i didnt really bothered. I believed that shop keeper and after that i never did believed again. With my current car i wanted to put good coolant so went for Poision Caltax coolant and its worth it. By the way i have seen reviews are not promising for abro too
do the relay module input test and see if it fails somewhere. Communication loss from modules is not a simple absolute problem, it can be intermittent too.
sir if you could please answer post 2880 previous page
dont try to listen to the calipers with a stethescope as they will be very loud regardless of any condition of the brakes. The discs cannot be rubbing the calipers as that would create a very very bad situation and you will actually see the worn down marks on the discs.
that lean is normal wear and tear, is the link loose?
No its tighten pretty well. I pulled out end links to inspect the bushings. The rubbers had pressed up marks on the points where the ends lean forwardsRest of the rubber bushing was Ok. Should i change it?
i saw a brochure about toyota injector cleaner which showed really good cleaning of intake valves and combustion chamber. i know carburetors have separate cleaners, but most people on the internet say they are the same thing in different bottles.
is it safe?
http://www.elamotors.com.pg/icms_docs/75966_Genuine_Injector_Cleaner.pdf
A 500ml bottle costs 2kish..just saying..
leave it alone. The bushing seems to be in good health, try to wiggle it with a strong lever and see if it flops around.
