no it cannot be due to the added weight but it for sure can be due to a bad fitting
jack up left side and make it rest on a jackstand
wiggle the tyre horizontally and vertically, if you have any movement you have to check what is causing the movement, if the suspension parts are good its probably the hub that has excessive play
after the above test you can also start the car and put it in gear to look for any anomalies when the tyre is moving
do the same for the right side and I'm sure you'll get to the cause of the noise.
unless of course the noise is generated from the rear.
