@xulfiqar..one freind is having a 3c turbo with original 5 speed gearbox in a w123 (300d), fuel average is 17,18 in city but the car does not go above 120km/hr..why is that?
3c t in w123 :-! What do you think a 3ct will pull a car weight nearly 1700kg above 120km/h BTW what made him swap a 3ct in a w123
Are these plugs fine or is their something wrong ?
Got them new 3 months ago
@xulfiqar bro plz suggest me a good workshop in Karachi
@avaiz84 i know 2 places reliable. 1 is at bahdurabad Mushir khan 03212435225, other is on shahrea quaideen Irshad 0300 2237538 mechanical work only
the rust brown is highly doubtful condition of plugs. please state the condition of engine. any abnormal temperature shot ups ? whats in the radiator tap water or coolant? cooling fans ? thermostat valve ? @naweed @syncview @ser_gtr
Plugs seem to be fine, I'd be worried if they get any cleaner
Sent from my VS980 4G using Tapatalk
Yes the car was over heating previously got the water pump Replaced and there was a leaky water jacket after that no heating Now the temp remains normal and no reduction in coolant level Because this is an old car and has been running on normal water since god knows when so i didnt experiment with the cooling system so left it as is These plugs were changed after I got the water pump replaced and the leaks fixed
Seems Like Burning Normal....Light Brown With Black Electrode Is Fine Until They Are Queit More Lightish And Dry...Then It Seems To Be Running On Lean Side
Sounds like a bad case of mould on your condenser. Spray some vinegar on your condenser and leave for a few hours.
Sent using Curiosity's onboard communications sytem.
Capsat sir what happened to your "70gb book ka giyan" you were about to share on other side of internet
@xulfiqar Recently i noticed slight pinging around 1.5k rpm in my 02" civic exi. What possible reasons can cause this? Also had to clean the throttle body as the engine was stalling on switching off ac at idle. This problem is now gone. Wanted to check the MAP sensor but it's screw is jammed. If i somehow open it can it be cleaned or should i buy one?
Speaking of w123 @xulfiqar sir I have very minor query about it for what reason did Mercedes install hood opening mechanism on non driving side seriously one have to ask the person sitting on the side to open hood for him
Seriously? Could be LHD to RHD conversion!
Didn't looked like one
Thanks for the reply........ I would ask the mechanic about this.
@xulfiqar does cylinder decarbonizing with water really work? I did it recently on a 2E spraying about 200ml of distill water in shots on carb throat, car seemed to idle bit smoother. engine was toasty hot.
was he high on weed?
@XulfiqarAOA Xulfiqar Sb
hope u r fine need u r expert advice on small requirementi just bought 2010 mini pajero auto trans / with inter-cooler and original 65k km mileage kindly guide me all the lubricants recommended for it; i ll be really grateful.e.g engine transmission differential power steering and 4X4 oilregardsAamir
Seen many w123 (300d) owner crying for mileage om617 does hardly 5-6km/l 17-18km/l (as he mentioned) is a dream
