The AFR data was collected by a device exhaust analyzer from which a pipe went into the exhaust of the vehicle.
As per injectors cleaning I have had it done for the first time. I didn't get a paper of the readings but I saw its pattern while on the machine and all injectors spray pattern was fine. The machine did a leak test too, which was passed. The volume on all of them was also fine as the tubes filled almost the same amount in all four . There was although a minute difference in readings but the guy said its OK if it within 3 cc or whatever the unit it displayed.
Please tell more about the mixture you have mentioned bolted on air cleaner box. No mingling done to it BTW.[/QUOTE]
do you have access to a toyota techstream or similar scan tool? and someone qualified to work on it, if Im assuming the AFR was 17:1 - that means the system is running ultra lean - which is exactly opposite of excessive fuel consumption.
I can point you to a place in Lahore if you are interested
