@xulficar @saboor73
Bro I find the following topic on my argument that by removing or cutting of a cat converter increase the pick of car but at same time it also increase the fuel consumption because O2 sensor gives wrong reading to ecu. This post is as follows in the answer of question of removing cat. and its fuel mileage effects on car.
With your catalyst missing, your downstream lambda probe (Oxygen sensor) will feed your ECU wrong data, which will try to compensate your fuel trim. It will over fuel like mad. Too much fuel going into your cylinders, over a period of time, will cause engine damage, due to "bore wash". This is whereby excess fuel washes the vital oil lubrication from your cylinder bores, causing premature wear. Your engine will begin burning oil, resulting in high oil consumption, visible as blue smoke. Diluting petrol with oil will result in a very low octane, which couple with a hot operating environment, will cause detonation, which could lead to holes being blown into your piston crowns. Or worse, if severe enough, detonation occurring whilst your piston's on its compression stroke could bend a rod. This could cause a conrod and piston to smash through the side of your engine block.
So I'll ask you - is there any sensible reason to run your modern car without a catalyst? You honestly listen to your "mechanic" who thinks it's a good idea to delete it? Where did you hear removal of a catalyst decreases fuel consumption?
