@xulfiqar thanks for the correct procedure.
can you clarify some more things.
1- Which wheel should be done first and the order in which to bleed (assuming we have a RHD vehicle).
2- Should the car be started when doing this? As the brake booster/braking system works when the engine is running.
3- Is it not better to have an inch of brake oil in the jar and the pipe submerged in it?
4- Lastly I've read that the correct procedure is to have a helper and have him first press the brake halfway and then the person should then loosen the bleed screw a little and tighten it back once there is no more fluid bleeding. After this the helper releases the brake and the whole process is repeated. (Your method as I interpret seems a little different, can we follow either of the technique?)
I have a Cultus 2012 clocked around 46k and look forward to do the DIY as the brake is not up to mark.
Regards
