Of course i am gonna scrap them..they are killing the looks of the car
6.50 lacs
That's a decent purchase price
The owner was not letting it go for 8.50 lacs but paise dene the us ne mere that's why
Hello Xulfiqar brother I have a question.
In my car (Alto VXR 2007) very little amount of engine oil is going to the air filter area? What could be the issue?
Sent from my ONE E1001 using Tapatalk
@xulfiqarThis was the second day after my friend sold his w203.he claimed that the fire was started from underneath side.the car was insured on the day the car was sold.he still has to pay 2 lacs to my friend.
Did a short circuit cause this?
Replace pcv valve.
any forensic reports?
as per ustad RA, the fire was caused due to the car having vilayat kee wiring....fail tuknolgee
Don't know what happened but according to the local people,the car was set on fire by the owner himself.
Assalmo alykom xulfiqar sir! Can you plz tell me about the vaccum diagram of this engine plz
@xulfiqarSome problems with my w202:1,the heater is not working though the ac works perfectly 2,i can move the gear lever without pressing the break.is that ok coz we have to press break in jdms
Xulfiqar bhai any idea how can I turn on this avg km display ?
@xulfiqar Hi. Would you please suggest about best transmission oil available in Pakistan as i am unable to find ATF 3314.Thank you
Xulfiqar, Can toyota 2l2 valve steam seals change without the head remove ? also pl advise about the best diesel OIL additives /treatment.
It's possible Diesel engine oil already contains handsome amount of detergents so no need to add the oil additive
@xulfiqar
I am noticing oil leak where the head meets the block. Engine: D15B. The leak (fresh oil) is at front left corner. Although I noticed some blackish oily layer at rear side as well.
I recently changed the valve cover seal so upwards its all dry. Is that normal for a failing head gasket?
See picture.
Most probably its the distributor ring
